6.9 Driveline
Old Jul 15, 2013 | 07:14 AM
Gather's Avatar
Default 6.9 Driveline
Relatively new to Diesels. Long story short my step-father gave me his old 85 6.9 3/4 ton 4wd
I was driving home and this happened, I need help. I need parts, prices, time etc.
Any links and input helps
Thanks fellow Diesel brethren
Old Jul 15, 2013 | 07:31 AM
Gather's Avatar
I did disconnect and drop the rear drive-line, Limped it home in 4 high.
Old Jul 15, 2013 | 08:47 AM
Opti-lube's Avatar
FormerVendor
The U joint is a simple and should be an affordable fix. Put one in that has grease zerks and keep it greased.
The broken yoke is an probably not overly expensive, but that nut is used to tighten down the bearings in the pinion and should be done by someone who knows what they are doing. There are crush caps in there that might need to be replaced to do it correctly.
For fun, how did it happen....
Old Jul 15, 2013 | 09:15 AM
Gather's Avatar
I appreciate the speedy reply Opti-Lube. Lets just say that when you try to power brake a 6.9 this is what may happen.
Ya priced out the Yoke and U joint totaled 80$ Now just got to take it to my local diesel shop
Blanton
Apr 15, 2015 06:29 PM
greasesheik
Apr 9, 2015 09:33 PM
tumble72
Nov 10, 2014 08:41 PM
Jimmi Neutron
9
Oct 18, 2014 03:18 AM
murderedf250
Oct 15, 2014 04:26 PM
