Help with 94 6.5l turbo lots of problems
Old Jul 14, 2013 | 11:15 PM
85suburban's Avatar
Default Help with 94 6.5l turbo lots of problems
Hello everyone. I just bought a 94 k1500 ext cab 4x4 6.5l td with the 700r4 trans. im very new to the 6.5 diesels. the truck has 327000 miles on her. I know its alot. it has a new ip and pmd relocator. no other mods. now the issues im having are :
No power. when trying to get up to speed it does just fine if you take it easy but if you give it a little more fuel the black smoke pours but no difference in pickup. 2- I have a knock from the passenger side of head. I was told its an injector knock. however its getting worst, it sounds like a valve slapping the piston but there is absolutely no miss and shutter. and the final issue is the truck feels like it has the same amont of power as my 6.2l. there is no turbo boost feeling. also I cannot hear the turbo spool either. the cel comes on but goes right out after 3 seconds. I am unable to pull the dtc. I just hope I didn't buy a turd and screwed myself with this truck.
Old Jul 17, 2013 | 05:17 PM
racer55's Avatar
Sounds like a no boost situation,check all the vacuum lines and make sure the vac pump is working,should have 18+ "'s of vacuum at the wastegate actuator and 24+"'s from the vac pump.
Old Jul 17, 2013 | 06:09 PM
85suburban's Avatar
so if I hook a boost gauge up to the truck I should be getting 18 plus lbs of boost?
Old Jul 17, 2013 | 06:17 PM
racer55's Avatar
No the vac system should have 18 inches or more of vacuum at the wastegate actuator and 24 inches or more from the vac pump.
Boost should be limited to 10 psi with spikes of 12 psi max.
Old Jul 21, 2013 | 05:47 PM
turbo2332's Avatar
the wastegates on these trucks are held shut by vacuum generated by the pump. if the pump goes out the wastegate actuator opens. this causes the turbo to be venting drive pressures all the time making spool-up way slower power will be way down unless in a WOT situation.
Old Jul 23, 2013 | 10:46 PM
85suburban's Avatar
wot?
Old Jul 24, 2013 | 12:03 AM
racer55's Avatar
wide open throttle
Old Jul 28, 2013 | 04:53 PM
dallonj's Avatar
Could be the map sensor located in front of the air cleaner unplug it and go for drive
Old Aug 9, 2013 | 02:33 PM
theiceman2713's Avatar
Also, this engine isn't supposed to be pouring black smoke like other diesels. If the guy before you turned up the fuel pump to the point where it belches black smoke you probably melted something, or blew the turbo.
huntman7
Sep 17, 2015 10:03 AM
InheritedDiesel
Apr 12, 2015 04:35 AM
MrMoose
Mar 15, 2015 06:05 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
