Transmission question
Old Jul 3, 2013 | 11:11 AM
tanner_bentley's Avatar
Default Transmission question
I have a 94 f250 7.3 turbo diesel. It has the 4 speed with overdrive auto tranny. I went to a local junkyard and they have an almost newly rebuilt 4 speed overdrive manual tranny that's in a f150.
My question is would that tranny fit to my engine? Or is there an adapter I could buy to make it fit?
Old Jul 5, 2013 | 10:01 PM
Route66Diesel's Avatar
FormerVendor
the 7.3 uses the big block bolt pattern, where as the F150 will more than likely have a small block bolt pattern.
There are adapters to make it happen, but they generally run in the $1500 or so price range.
You may be better off to go with a newer ZF transmission from a 7.3.
Why are you planning to go to a manual trans? An auto trans behind a turbo diesel is a beautiful thing. You may be happeir and money ahead to stick w/your auto and doing a mild rebuild on it. Have to figure in manual pedals, clutch linkage (or hydraulics), flywheel, clutch, drive shafts, etc.
Old Jul 7, 2013 | 07:08 PM
4x4manonbroke's Avatar
yeah I would love if it mine was an auto ....
Old Jul 9, 2013 | 07:59 PM
these engines can use the Big Block 460 5spd ... my understanding is there is some fab required ( like drilling ) ... if you can find one in decent condition...
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Trevlar11
Dec 11, 2014 03:30 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
