1999 7.3 INJECTOR ISSUE
Old May 12, 2013 | 10:05 PM
JR74's Avatar
Default 1999 7.3 INJECTOR ISSUE
I have early 1999 E350 with injector issue. I have a set of injectors out of a 2002 7.3. Are these injectors compatible with my early 99? The # on the 02 injectors is AD1831551C1. My 99 is a stock E350 that is a service vehicle and i am Down and Out of Service. THANKS
Old May 12, 2013 | 10:27 PM
joebob3093's Avatar
Moderator
they should work just fine, they are just a little bigger
Old May 12, 2013 | 10:41 PM
JR74's Avatar
My tank was rusted and contaminated fuel system. I replaced tank,cleaned mixing valve,replaced pump,rebuild fuel bowl and replace FPR truck still has no power and misses and vibrates bad. With new FPR spring my fuel pressure is around 60PSI before the filter but very erratic the needle bounces all over when you accel but let off pedal and coast it stays right on 60PSI. I have that 02 motor and want to swap the injectors so i can get back to work.
Where would be a good place to send my old injectors for rebuild?
Old May 13, 2013 | 12:57 AM
joebob3093's Avatar
Moderator
farmers diesel does all my injector work
Old May 13, 2013 | 01:14 AM
JR74's Avatar
Well thanks for the help. I really hope switching these injectors gets me back on the road and works out. Where is Farmers located?
Old May 13, 2013 | 01:30 AM
joebob3093's Avatar
Moderator
Think he is in Athens Texas
Old May 13, 2013 | 09:50 PM
JR74's Avatar
Need your opinion about injector o-rings... I pulled the 02 injectors to swap the o-rings actually look like new should i replace them or use the if its not broke don't fix it rule. I just have to get back IN SERVICE so i can go back to work.
Browe347
Dec 11, 2016 02:59 PM
Toms73
Mar 23, 2015 08:31 PM
racinfast002
For Sale
Jan 7, 2015 12:46 PM
Dec 1, 2014 08:10 AM
Browe347
Sep 30, 2014 11:35 PM
