transmission ?
Old Apr 6, 2013 | 12:28 PM
rrimpa's Avatar
Default transmission ?
I have a edge comp and was wondering what auto trany you think I should run? I do a lot of hauling and also pull my camper,which transmission and torque converter do you think I should run ? I want something that will hold up over time .
thanks for any help
Old Apr 8, 2013 | 11:57 AM
SRTcummins's Avatar
Goerand triple disk torque converter. Valve body. Or if you use all your money on the torque converter get a shift kit.
Get a transmission temp probe. And possibly a TC Lockup switch if your towing down hill and you want to use the engine as a extra brake.
What gearing do you have in the rear?
And keep in mind if you upgrade all this and have some power infront of it you may need a flex plate and input shaft.
Old Apr 9, 2013 | 01:13 PM
rrimpa's Avatar
not really sure what the gearing is but the truck runs at 2100 rpm at 60 mph
it has 245/75/16 on it
Old Apr 10, 2013 | 10:51 AM
SRTcummins's Avatar
If I'm not mistaken then you have 4.10s. At 2100rpms I'm at 75 and I have 3.55s on 285s
Old Apr 10, 2013 | 04:57 PM
Blair@BD's Avatar
FormerVendor
How heavy do you tow? what are your Horsepower goals in the future? Are you ever going to Race or sled pull with the truck. Answer these questions and I can help point you in the right direction, as what works of one person may not be the best for the next person. Plus you can go way over kill and spend money on something that you will never ever use.
Hector
Old Apr 10, 2013 | 05:15 PM
rrimpa's Avatar
I pull about 14 to 15 k and I don't plan on pulling or racing
sorry correction, 2100 at 65 with 245's
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
