03 cummins problem
Old Jan 23, 2013 | 08:56 PM
Mad mike's Avatar
Default 03 cummins problem
One afternoon truck would not start temp around 45 cleaned battery cables fired up set 3 hours still fired up next morning fired up went to work after work no start left it at work next day unhooked battery cables for about 25 min hooked them back up and it fired up any ideas on what is causing this issue?
Old Jan 23, 2013 | 09:48 PM
lunk's Avatar
batts may be going bad if they cant spin the engine fast enough then wont start on mornings 45 and colder
Old Jan 24, 2013 | 06:17 AM
Mad mike's Avatar
Battery are 1 year old the odd thing is it will start after I unhook them for about 25 min then it might start for the rest of the day then a day later it might not start the do the same thing with the battery's and will start again
Old Jan 24, 2013 | 10:28 AM
Bigg Redd's Avatar
Have your batteries checked anyway. Cold weather is murder on batteries. If you dont have battery blankets, get them. They protect the batteries against cold and too much heat, which is also hard on batteries. Also clean all ground connections, and check the battery isolator solenoid (just under the passenger battery). It may be faulty. Just tossing it out there.
Old Jan 24, 2013 | 08:35 PM
Mad mike's Avatar
Thanks for the info I will look at that
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
jeremy01995
Sep 14, 2015 06:34 PM
signoremint
13
Oct 21, 2014 07:21 PM
