2001 cummins wont start
Old Jan 19, 2013 | 01:54 PM
swabey's Avatar
Default 2001 cummins wont start
I just bought a 2001 cummins yesterday, i checked over and everything was good. It fired up no problem in the cold, and drove it back home 300km truck ran real strong. I had it pluged in all night and when i went to fire it up it would not start. bloke heater is working great everything is worm, fuel filter isnt pluged. any suggestions on why it wont start?
Old Jan 19, 2013 | 01:58 PM
H.R.D's Avatar
What does your fuel pressure look like?
Are you getting fuel to the injectors? Crack some injector lines and have someone crank the starter and look for fuel coming out at the lines you have cracked.
Old Jan 19, 2013 | 02:02 PM
swabey's Avatar
Im no im getting fuel before the lift pum, havent craked injectors yet. if im not getting fuel to injectors what would be the couse of that?
Old Jan 19, 2013 | 02:39 PM
H.R.D's Avatar
The IP is not working.
Do you know what your fuel pressure is coming from the lift pump?
Old Jan 19, 2013 | 03:01 PM
swabey's Avatar
I just cracked 2 injectors, i got a little bit of fuel from the first 1 and none from the second 1. i havent put a fuel pressure gauge in yet so not to sure on the pressure. is it possible that the injector pump is frozen, it is -20.
Old Jan 19, 2013 | 03:09 PM
Sounds like your Injection Pump
Luke
Old Jan 19, 2013 | 04:42 PM
swabey's Avatar
im just trying to be sure before i order a new pump. i can hear my pump working, and im getting fuel at my return. I cracked 3 injectors and got a little fuel at the first 1, is it possible that its sucking air somewere?
Old Jan 19, 2013 | 05:43 PM
H.R.D's Avatar
Yeah, it is possible that you are sucking air also it is possible that your fuel gelled up...
tntmechanic
May 18, 2016 04:59 AM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
mcclusk
Feb 21, 2015 09:50 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
