7.3 hard start
Old Jan 10, 2013 | 01:56 AM
iam4x4's Avatar
Default 7.3 hard start
Hey guys having issues with the 7.3 it's a very hard start, but once it's started it starts everytime for the rest of the day. Ford installed some new injectors ad all glow plugs, it's blows a little blue and has a little bit less power, I'm assuming either my motors going if my compression is bad or the HPOP. Any ideas? And also a good price to have a 7.3 rebuilt? With all the work done by me or a motor shop? Thanks
Old Jan 10, 2013 | 10:30 AM
95powersmoker's Avatar
You need to dive in with a multimeter and a scanner... Test your Glow plug relay first... Then find a scanner that works with powerstroke's and can give you ICP and DC numbers... You can also test your compression if you are worried about that...
Make sure your fuel filter is good and no crap in your fuel bowl. Make sure your oil is at the level that it needs to be. How long ago did the injectors get installed?
Old Jan 11, 2013 | 01:31 AM
iam4x4's Avatar
Injectors are less then 1000 km it was originally taken to ford for the hard start and they replaced the injectors and glow plugs, it helped but still not very good to start. I now have a video of it starting if you can send me your email I can send it to you
Old Jan 13, 2013 | 09:51 AM
poor boy,s toy's Avatar
check your batteries i had a bad battery
Old Jan 13, 2013 | 10:55 AM
plowboy1138's Avatar
Check your grounds, connections, glowplug relay, batteries, and high-pressure oil pump
Old Feb 5, 2013 | 01:32 AM
iam4x4's Avatar
Ended up being te HPOP and a few injectors were going thanks for the help guys
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
trab123
Feb 9, 2015 09:44 AM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
