ARP Head Studs
Old Jul 19, 2012 | 02:08 PM
helton87's Avatar
Default ARP Head Studs
i am planning on getting the ARP Head Studs for my 5.9 and was wondering if anybody has tried this and if it worked for you, not trying to take the easy way out just the cheap way out.....i was wanting to save some time and money but not sure if it will work or not....will it work if i start from the inside and go clockwise and take out one stock head bolt and replace it with an ARP head stud and torque it to spec and take the second stock one out and replace it. so on and so forth?
Old Jul 20, 2012 | 06:32 AM
K80's Avatar
K80
I've done the pull bolt, install stud trick. It isn't the completely correct way but it has worked for me. Use the recommended torque sequence. When installing a stud I torqued it to about 65ish. When they were all in, then gradually go up to final torque.
Old Jul 23, 2012 | 08:09 AM
helton87's Avatar
thanks! ill have to try that!
Old Jul 29, 2012 | 10:19 PM
CHEMMINS's Avatar
Shops do it all the time.
Old Jul 30, 2012 | 07:22 AM
helton87's Avatar
SWEET ill have to give it a try! thanks!
Old Aug 24, 2012 | 08:52 PM
calltrex's Avatar
Start at the back because u will be tired when your done
gd1996
For Sale
May 15, 2015 09:42 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
