sitting diesel?
Old Jul 14, 2012 | 05:45 PM
7.3 idi 1990's Avatar
Default sitting diesel?
My dads construction company has an 89 service truck, it has the 7.3 idi, and what should i be on the lookout for cause its been sitting, i know there is no water in fuel. I wanna get it running again.
Old Jul 15, 2012 | 09:35 AM
DieselCrawler's Avatar
depends on how long is has been sitting. year and a half? fire it up! any longer than 2 years and fuel will be starting to go bad.
Old Jul 15, 2012 | 10:23 AM
only about 6 months but i read on that diesel wil stay fresh for ten years. Is that true?
Old Jul 15, 2012 | 12:07 PM
not this new ****. lucky to last a year or two.
Old Jul 15, 2012 | 11:22 PM
chris142's Avatar
My Peterbilt sat about 20 yrs unstarted. 2 good batteries and some air in the tires had it running and driving home. Ran fine.
Old Jul 16, 2012 | 12:14 AM
2004LB7's Avatar
may be a good idea to take a spare fuel filter with you in case algae or debris clogs it. but at only 6 months it is not too likely.
Old Jul 16, 2012 | 06:55 PM
we got the fuel to the filter but should i crack the lines next? Or take the filter off, it wasnt firing when fuel was coming through shrader valve, .
Old Jul 22, 2012 | 11:23 AM
4x4manonbroke's Avatar
It will need to prime its self......crank it a bit... might think about adding some fresh fuel as well... can also prime the fuel filter with atf ... its thicker and helps get things moving
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 6, 2015 03:20 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
