Lift pump confusion
Old Jul 10, 2012 | 02:07 PM
BigRed55's Avatar
Default Lift pump confusion
OK so I bought my 03 cumins back in augist of 2010 and I love my truck. But with 98K miles I don't think the lift pump is long for this world. That being said I have been looking at some of the post about after market replacements and was curious about how to bypass the filter mounted pump as it appear that the inlet is an O ring seal and is held in place by the pump itself. In the post that I have read it appears that easiest installation is the BD pump but again I'm not sure about how to bypass the factory pump. any ideas?
thanks
reddog
Old Jul 10, 2012 | 06:32 PM
OC DIESEL's Avatar
would you consider a FASS fuel system?
Old Jul 11, 2012 | 11:10 AM
rufushusky's Avatar
thanks
reddog
If you add your own filters you can totally bypass the stock filter and pump assembly (I am assuming you have the canister mounted pump).
If you want eliminate it entirely you could get this..
Glacier Diesel Power - Product Detail
Or if you want to tap into the canister you will need one of these set ups...
With fuel pressure ports..
Without...
FYI most raptor or FASS HPFP kits come with the fittings to tap into the stock canister I believe.
Last edited by rufushusky; Jul 11, 2012 at 11:10 AM. Reason: Automerged Doublepost
Old Jul 11, 2012 | 11:29 AM
Farmboy 2.0's Avatar
The raptor pumps for those years come with the adapters to hook up to the fuel filter canister. I would recommend going to a fass or air dog with the good water seperator and good 2 micron filters to filter fuel 5 times cleaner than the stock filter.
Old Jul 11, 2012 | 12:27 PM
rufushusky's Avatar
Actually the baldwin drop in for the 03-07 is very good. 5 microns absolute and a 94+% water stripper.
Personally, I am not a fan of odd threads used on the AD fuel filter and the **** poor performance of the FS19768 water stripper.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
