home made stacks
Old Jun 26, 2012 | 04:52 AM
Redneck GI JOE's Avatar
Default home made stacks
hey guys im looking into making a homemade stack kit. i was wondering if anyone had the dimensions from the turbo back, ie. down pipe to 90, 90 to 90, 90 to y. or should i just create my own. im just trying to plan it out. i worried about the the proper placement of the hole in the bed. want to make sure i cut it right the first time, that im not to far forward or to far back. thanks for all and any feedback
Old Jun 26, 2012 | 06:23 AM
dmaxkiller's Avatar
i used 3x8" square tubing for mine. capped the ends off cut my holes and welded the stacks to the tubing. then made mounts to mount to the bed. cut a hole in the bottom and used 4" flex to come off old exhaust. worked really well and was really sturdy
Old Jun 26, 2012 | 07:10 PM
I'm looking to do 5" underneath with 8" straight cut stacks. I was trying to get away with out using flex pipe but I realized I need it for flex. My biggest concern is where to put the hole so it's not too close or too far from the bed rails
Ok changed my mind I'm going with 7" stacks
Last edited by Redneck GI JOE; Jun 26, 2012 at 07:10 PM. Reason: Automerged Doublepost
Old Jun 26, 2012 | 10:08 PM
dmaxkiller's Avatar
so set the stacks inside the bed. mark it and then cut the holes from the top down. and then slide in your tubing (would save u alot of room) and then mount to frame and then cut the hole in the bottom of it and weld in your pipe to flex to..... the problem of doing a below bed cross pipe is getting to the welds on the stacks to the cross pipe. that and its gona be almost impossible to remove the stacks once installed. u have to use flex no matter what stack setup. the tq of the engine flex's to much and would eventually break the welds.
Old Jun 26, 2012 | 10:22 PM
1999stroker's Avatar
Id just cut a hole in the bed towards the passenger side may've an inch from front of the bed and use a y pipe to go to your stacks, or my buddy used a piece of box tubing and cut two holes and rigged up his stacks that way.
Sent from my dumb phone!
Old Jul 3, 2012 | 01:05 AM
Thanks for all the info guys.
ASarsano
Ford Powerstroke 2011-Up 6.7L
18
Dec 14, 2015 12:54 PM
autostroker
Jul 4, 2015 10:39 AM
tim12valve
May 29, 2015 05:19 AM
tbreddiesel
Thoroughbred Diesel
Oct 14, 2014 07:44 AM
