shutter while accelerating
Old Jun 23, 2012 | 08:28 PM
bowietrucking's Avatar
Default shutter while accelerating
new trans a few months ago, new ring and pinion, u joints and carrier bearing 2 wks ago. the shutter is felt mostly when accerating hard in 1st gear while towing (which i do 99 percent of the time) and a slight shaking/vibrating/shutter when cruising at 65mph which i always before blamed on the trailer. i don't think its the trailer now, as i had to drop into low 1 to pull a really steep hill the other day and the thing was jumping around like awful. any ideas??? i most certain it did this with the old trans and before all the rear end work was done to so that kinda narrows it down. i was thinking engine mounts?? tried to look under there last night when i got home but its very hard to see how they are with the plate there.
Old Jun 25, 2012 | 05:32 PM
TheRobenator's Avatar
Maybe the tranny shop put a clutch pack on backwards or two steels together?
And I am guessing this is a 5 speed manual tranny, possible clutch?
Also did you check tranny mounts?
Old Jun 29, 2012 | 02:17 PM
automatic, brand new from ford. the truck always has done it since 61k on it when i bought it and now seems worse with 161k on. trans mount appears fine, checked that. thinking i might be missing something simple! exhaust isnt hitting anywhere, u joints are new, hmmm
Old Jun 29, 2012 | 05:35 PM
fordornothing's Avatar
is the drive line bolted on tight? i've had thos bolts come loose and it caused a hellacious vibration.
Old Jun 30, 2012 | 08:14 AM
hey man. yes, all bolts are tight but i'm kinda leaning towards the possibility of it being bent or out of balance. i gotta find some spare time to get the thing to the the driveshaft shop here soon...
Old Jun 30, 2012 | 06:28 PM
just checking. i understand your thinking on blaming it on the trailer. pulling my buddies 25' goose it's a shaking sob after 70. possible u joint? maybe a bearing in the rear end?
Old Jul 6, 2012 | 08:41 PM
new u joints, new ring/pinion and all bearings recently. just took the driveshaft to the shop and it was out of balance by a good bit he said. towed with it today, it may be slightly better but still not as smooth as my dam 95 is! pissn me off, ready to go buy a new one but dont want the new engines!!!
Old Jul 7, 2012 | 10:57 AM
it could be internal some where.
doodieroot
May 10, 2015 11:48 PM
5280
Dec 24, 2014 09:40 PM
