95 F350 front axle u-joints
Old Jun 7, 2012 | 01:33 PM
1995ford's Avatar
Default 95 F350 front axle u-joints
How big of a pain is it tot change the front axle u-joints on a 95 F350. Is it more than I want to take on, or is it something I can accomplish without great difficulty I'm usually up for a challenge but.........
Old Jun 7, 2012 | 06:20 PM
Gaius's Avatar
I think they're pretty easy. But then, I'm kind of a big deal.
Seriously though, they're not bad. Just get yourself (or rent) a quality ball joint press to press out the u-joints.
Old Jun 7, 2012 | 10:18 PM
1995ford's Avatar
OK I think I have to change the front differential seal as well, could be a long day!
Old Jun 8, 2012 | 05:12 PM
fordornothing's Avatar
pull the wheel off, then the 4wd hub. there are 2 spanner nuts in there. in between them is a washer with a key and a bunch of holes in it. the second spanner nut has a smal pin, do not break that off. then pull the whole hub off. 5 bolts hold the spindle on. the back side of the spindle is a press- on fit to the knuckle. lay a block of wood on the spindle and hit it side to side and work it off. when you get that off the axle slides out. since you have to do the inner seals as well, pull the drive shaft and the yoke. then pull the diff cover off and then pull the carrier. the inner seals are a light press- on fit in the housing and on to the axle shaft. then reverse all the steps. when you put the axles back in, make sure they are lubed up good so you don't knock the seals out out.
Old Jun 8, 2012 | 11:10 PM
1995ford's Avatar
Thanks for the detailed info that helps a lot. I feel much more confident when I have good info on how to.
Thanks again!
Old Jun 9, 2012 | 09:05 PM
it's really not that bad. but i've had the front end apart on these a time or two. LOL if you have any other quetions on it fell free to PM me. the inner seals are relatively expensive, but the seal spins with in its self.
Old Jun 11, 2012 | 09:44 AM
1995ford's Avatar
I appreciate it I will definitely will message if I have any questions.
Thanks again!
Old Jun 11, 2012 | 06:34 PM
not a problem!
Natenelson1
Jan 19, 2015 07:23 PM
2FordStrokers
Jan 11, 2015 09:40 PM
natenel1
Oct 26, 2014 03:09 AM
