weak lift pump
Old May 30, 2012 | 03:23 AM
scarnes's Avatar
Default weak lift pump
i think i have a weak in-tank lift pump (lift pump on the block was removed by previous owner).
A couple weeks ago it started hesitating between 45-55 mph under load until i gave it more throttle or let off throttle. otherwise started and ran great. drove it that way for a couple weeks before i was told it was my lift pump. havent driven it since. i do have two questions though
1) do you think my vp44 is ok seeing as the problem has not progressed beyond the hesitation and will not be driven at all until i replace the pump.
2) im on a tight budget. would the stock replacement fass pump be sufficient for my particular application with the edge chip or will i require something more? i would prefer to stick with fass as i have read really good reviews about it. but if theres something better for a tight budget im all ears.
unfortunately i cannot do anything about this until i start bringing in some money again. Im a school bus driver and i havent had any work since school let out may 17th and i wont start driving for summer school until tommorow then i need to get back on track with bills and save up to afford the new pump. suck but it is what it is.
appreciate any input...
Old May 30, 2012 | 07:11 AM
RAW's Avatar
RAW
As you have an EJWA, what is your fuel pressure?
It could be fine, it could be damaged, hard to say unfortunately.
I'd do a FASS Platinum as then you would have an extra filter. Otherwise, an AirDog Raptor would be a little less money and work fine.
Old May 30, 2012 | 01:46 PM
scarnes's Avatar
my fuel pressure was staying steady at 9-10 psi at cruising which i learned a few days ago is too low. 12 psi at startup.
thank you for the pump recommendations
Old May 30, 2012 | 02:15 PM
RAW's Avatar
RAW
9-10 at WOT is the lowest you want to see. A healthy 14-18 is good at idle or cruising.
Old May 30, 2012 | 07:35 PM
scarnes's Avatar
i guess ill find out when i replace the lift pump whether its good or bad. thank you for your time
Old May 31, 2012 | 01:17 AM
01quadcab's Avatar
I hope your doing something other than another in tank pump
Old May 31, 2012 | 12:05 PM
scarnes's Avatar
01quadcab, i parked the truck until i can afford a fass 150 but im gonna use the current in tank pump for the fuel gauge. i want to do it right the first time unlike the previous owner did hence the reason im having this issue.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
