48RE trouble
Old May 23, 2012 | 10:18 PM
TKC2000's Avatar
Default 48RE trouble
The trans seems to be "stuck" in drive. Meaning, I can shift the gear selector to the different positions with no problems. The truck drives normal for the most part. No fluid has leaked and the level seems good and in good shape. There is no grinding or binding or banging. When I select Neutral the truck is still in gear, it still drives forward. When I select Reverse it rolls/drives into it then stops. I select Park and it does the same thing as Reverse. I can run thru the gears manually, D1, D2, D, and all seems OK. I haven't done any road testing with it since this started happening, just up and down the street in front of the house. It's a Garmon built trans with billet input shaft, laminated flex plate, upgraded VB and triple disk TC. The truck has 152K miles, the trans has 50K of that but not sure exactly since I bought it from a friend with a salvaged truck, but I don't think it had too many miles on it then.
I need to get this figured out soon. I was planning a trip up to Morgantown, WV and seeing some friends in MD.
Old May 29, 2012 | 10:02 AM
cummins4x4usmc's Avatar
seems pretty weird but start with garmon about it. call him up or email him about it.
Old May 29, 2012 | 12:16 PM
Whit's Avatar
Site Mascot
sounds like linkage adjustment
Old Jul 2, 2012 | 03:46 PM
aggiecowgirl12's Avatar
Yea, I'd go with the linkage... We had the same issue too... just for ***** and giggles, see if you can get her into neutral while running and hot, and check the fluid again... How dirty is the ATF4?
Old Jul 12, 2012 | 03:14 AM
rlawless's Avatar
Check the shifting cable mount to ensure it has not slipped out of its bracket.. It's located on the driver side of the tranny just before the cable enters the case.. It has two small tabs that hold it into the bracket and it can slip out at times allowing the cable sheath to move.. Also it could be the shift cable linkage bolt that connects the cable to the shifting shaft where it enters the tranny.. It's located just after the above mentioned cable mount..
Old Jul 12, 2012 | 08:45 AM
dangerous1965's Avatar
Exactly what Rlawless said!
Old Sep 26, 2012 | 11:16 PM
oilpatch welder's Avatar
Default trans
i know this thread is old , but mine just done the exact same thing . had to get it rebuilt, direct clutch pack gualded together, also if you put in nuetral and try to pull truck backwards it is locked up and will spin the engine, this info is for others reference im sure youve already figured this out .
Kfohne21
10
May 12, 2022 10:13 AM
jeremiah1
Jul 21, 2015 06:35 PM
Bighouse
Apr 9, 2015 06:51 PM
Gizmo52
Jan 6, 2015 11:58 AM
7.3stroke
Oct 27, 2014 06:25 PM
