Edge comp on and now my truck stays at full throttle
Old May 9, 2012 | 11:48 PM
robertchase199's Avatar
Default Edge comp on and now my truck stays at full throttle
i just installed an edge comp box and it drove fine at first i drove it about ten miles and my rpms started jumping then ten more miles the truck stays at full open throttle. any ideas?
Old May 10, 2012 | 07:07 AM
RAW's Avatar
RAW
Try removing the Edge Comp and see what happens. Determine if it is an Edge issue, or a truck issue. Any codes?
Old May 10, 2012 | 09:38 PM
its not the edge. i disconnected it fully and it still did it i pull off the plastic cover off of the throttle cable assembly area and the top cable on the engine side is slack. no tension whats so ever. i traced it back to an assembly on the front underside of the driver side battery.
Old May 10, 2012 | 10:06 PM
Whit's Avatar
Site Mascot
reset the APPS
turn key on but dont start
slowly fush throttle pedle to floor
slowly release throttle pedle up
turn key off
start truck and see what happens
Old May 10, 2012 | 10:08 PM
also there was i think a small vacuum hose that came off of the assembly at the front underside of the drive battery that i broke messing around with trying to see what was happening. will the apps reset put tension back on the cable?
Old May 10, 2012 | 10:12 PM
RAW's Avatar
RAW
No, thats your cruise control vacuum pot.
Whit's Avatar
Site Mascot
no this is the electrical end only
Old May 10, 2012 | 10:14 PM
ok so there is only tension on that cable when cruise is on. what about the vacuum hose that i broke playing with it. what does that do?
also the pedal isnt sticking and seems to be working fine. so would the edge have messed up the volts going through the apps?
Old May 10, 2012 | 10:15 PM
Whit's Avatar
Site Mascot
the edge will have no relation at all to the APPS
Old May 10, 2012 | 10:18 PM
ok so when we removed the whole triangle shaped throttle assembly (the black box on top of the vp) to get the wires on the pump to tap it for the edge, could we have stretched a cable or messed up the apps? or is that a fairly tough system
