99 f350 12v tach problems
Old Apr 18, 2012 | 10:14 AM
deck60's Avatar
Default 99 f350 12v tach problems
trying to get my tach working
I am not going to go to destroke or ford cummins half the fun of doing a conversion is figuring it out
I tied the dodge setup didn't work
so I did the ford setup with the cam sensor take #85 the cam sensor wire and the #48 wire the tach wire and wire them together before pcm
wondering it I might have the sensor to close to the harmonic about .030
I ground in the 2 extra notches so I have 4
I tested wire from sensor to the pcm block I haven't tested the other to the tach yet
Old Apr 19, 2012 | 07:16 PM
timdale's Avatar
That's how I have mine set up and it works, but I want to check it at cummins with an optical tach to see how close it is, seem like it's a couple hundred rpm's too high on the gauge. I used a 99 escort crank sensor ($19.99 @ orielly's), but I think any two wire sensor will work. I'll try gettin a pic of the mount, but from reading other thing you figured out, making a mount will be no prob!
Old Apr 19, 2012 | 08:56 PM
deck60's Avatar
I will get a pic of it tomorrow how close did you put your sensor I am wondering if I am too far away
Old Apr 19, 2012 | 09:25 PM
timdale's Avatar
.018"
Old Apr 20, 2012 | 12:22 PM
deck60's Avatar
well that might be the issue I am sure I am at .040 I will set it to .018 tomorrow
it works !!!!!! timdale was 100% right on about the .018
tie 85 and 48 togethere before the pcm hook one wire at sensor and the other wire will go to #85 dark green ground the other wire at sensor
I used the cam sensor from a v10 I think most of them are the same
made a bracket
installed it here is where i messed up I set it at about .040 maybe a little more
I was told it needed to be .018 so I set it to .018 and I have a tach
here is my photo bucket with my bracket and much more stuff
http://s1125.photobucket.com/albums/l582/deck60/ford%20cummins/
Old Apr 29, 2012 | 10:28 AM
timdale's Avatar
Deck60, how accurate do you think your tach is? I think mine is about 500rpm,s too high, on the gauge. At 65 in 5th the tach reads 2600. According to a couple rpm calculators I've used it should be 1850-1900, with the .77 o/d gear, 3.73 rears and 305/65-18 tires. Maybe I'll mess with the sensor clearance. At idle it's about 300 too high, so the higher it revs the more it's off
Old Apr 29, 2012 | 04:52 PM
deck60's Avatar
at Idle is reads 650-800 range and wide open against the governor about 2600-2700 and I am all stock so I think it is right on
Old Apr 29, 2012 | 05:41 PM
timdale's Avatar
Maybe the sensor I used (99 escort) is causing me problems. You used the v10 cam sensor?
Old Nov 14, 2012 | 10:38 PM
motoxraca33's Avatar
sorry to ask random an off topic question but where did you guys find a wiring diagram for the pcm?
Old Nov 15, 2012 | 05:34 AM
timdale's Avatar
I have a friend with a auto shop, got it from him. Most any repair shop should have what you need
tom88k5
Jun 16, 2015 12:57 PM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
kalarachelle
Feb 21, 2015 03:25 AM
short12
Jan 2, 2015 04:56 PM
angies04
Sep 29, 2014 04:11 PM
