fummins swap problems!!
Old Apr 15, 2012 | 10:35 PM
12vfummins's Avatar
Default fummins swap problems!!
i need some help and some pointers on how to run my tanks on my 96 f250, it had a 351w in it with dual tanks and i wanna check this off my list so i dont have to deal with it any more. ima get an airdog 150 so its confusing me on how to run it. the tank selector used the vaccum pressure to switch the tanks, shoujld i ditch the dual tanks and use a large capacity tank (38 gallon) that sits in the rear??
Old Apr 16, 2012 | 07:03 AM
cumminsf150's Avatar
I would just get a manual hand valve to switch tanks. Or get a tank selector from a diesel
Old Apr 16, 2012 | 08:32 AM
93_Fummins's Avatar
I put a 33 gal poly Bronco tank in the rear (had to put in an angle iron crossmember for the back strap mounting point, but it fit prefectly) with a draw straw, connected straight to my AirDog with all 1/2" line. I then put a small electric transfer pump from the front tank to the rear and I just use the front as a transfer "reserve" tank.
The reason I did this for now is because I want to come up with a way to make the Diesel dual-tank valve all 1/2" for reduced restriction, then I'll plumb the tanks as they were with the switch in the stock diesel configuration. Food for thought...
Old Apr 16, 2012 | 08:40 AM
deck60's Avatar
Default valve
I found this valve it is a stacked valve so you can run 2 tanks it is 1/2 line so when you switch you switch both fuel and return a little pricey but is the right product
quote :
A stacked valve is available, it uses 1/2" NPT for the main fuel lines and 3/8" NPT for the return fuel lines. The price on this valve would be $192.29 + shipping. This isn't an item we keep in stock, but can have it in stock within a few days. You can call us with the order or we can make a listing on ebay for you. Let me know if you have any other questions.
Thanks,
John White
sales@shopwhitesmarine.com
1-864-443-2644
Old Apr 16, 2012 | 12:34 PM
12vfummins's Avatar
Yikes, yea that is a lot for a valve, I cant use my gasser pick ups right?, since they freeze up in the winter, if i just do one large tank what kind of a sender should I use
Old Apr 16, 2012 | 10:28 PM
deck60's Avatar
no they will not work the socks will not let diesel through in the winter
the valves are spendy I want to go to a truck salvage yard some of the old chevy and gmc that had dual tanks and diesel should have them
Old Apr 17, 2012 | 01:09 AM
not enoughsmoke's Avatar
for $200 you can buy a brand new 38 gallon rear tank and be done with it
Old Apr 17, 2012 | 06:07 AM
12vfummins's Avatar
Is that the one out of a bronco or the one for the 87-89 version
Old Apr 17, 2012 | 09:41 AM
93_Fummins's Avatar
Gas Tank, 33 Gallon Plastic 90-96
I used this one with my stock diesel sending unit (since I used a Draw Straw anyway) and just used a piece of stainless TIG rod to make a new fuel level float rod for the deeper tank
Old Apr 17, 2012 | 10:39 AM
Ford F350 Truck Fuel Tank at 1AAuto.com with how-to installation video.
