New to cummins fuel problem
Old Apr 4, 2012 | 02:01 PM
4x4kingx889's Avatar
Default New to cummins fuel problem
We have a 2002 dodge 3500 dump truck that has been acting up we took the tank off to clean it and noticed it does not have a fuel pump in the tank? Is there a inline LP some ware? when taking the Assembly out of the tank it was cracked and All I can find online is the conversation fuel pumps what is the best way to go about fixing this?
Old Apr 4, 2012 | 02:17 PM
cummins_guy's Avatar
if your truck is a diesel and has a cummins 5.9l 24v vp-44 fuel pump.
your lift pump is on the block (driver side) follow the fuel lines, they will lead you to it.
also to help with your fix, need more info, what is cracked?, pictures say a thousand words.
Last edited by cummins_guy; Apr 4, 2012 at 02:17 PM. Reason: Automerged Doublepost
Old Apr 4, 2012 | 02:44 PM
The plastic connections where you connect the fuel lines to the tank Assembly and all I can find online is fuel pump Assembly's
Old Apr 4, 2012 | 05:06 PM
jkidd's Avatar
A good aftermarket lift pump is always a good idea.
Old Apr 4, 2012 | 05:52 PM
Is it better to do the in tank pump or a inline Lift pump?
Old Apr 7, 2012 | 03:17 PM
Rooster24v's Avatar
inline lift pump is the way to go..
Old Apr 7, 2012 | 04:22 PM
Ok Thanks and I can't seem to find a replacement Fuel canister is a jeep liberty 5140832AB a direct fit?
Antwhite19
Mar 26, 2020 04:58 PM
Dbleo351
Nov 20, 2016 09:34 AM
jeremy01995
Sep 14, 2015 06:34 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
