1997 Ford Powerstroke
Old Mar 31, 2012 | 12:05 PM
Tyler Golis's Avatar
Default 1997 Ford Powerstroke
My steel rear wheels wont come off the rear hub. I have been trying to pound it off and its still stuck. Dont Know what to do????
Old Mar 31, 2012 | 10:16 PM
fordornothing's Avatar
lay a 2x4 on the wheel and waylay it with a big hammer. you might need to spay some penetrating oil around the hub.
Old Apr 1, 2012 | 05:58 AM
kb3ejw's Avatar
had this problem with my Rover.put the lugnuts back on but loose and try moving the truck back and forth to break the rim loose.
when remounting the rim use some anti seize on the drum surface to keep this from happening again.
Old Apr 1, 2012 | 04:09 PM
justanother92's Avatar
Or if you are planning on getting new wheels you could heat the wheel a little which would cause it to expand, and should let it slide off.
makuloco2000
Dec 20, 2015 11:19 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
