just bought a 91 ford f-350 7.3 idi turbo diesel
Old Mar 19, 2012 | 10:52 PM
Mike Roose's Avatar
Default need help on a 7.3 idi
so i just got my first ford...its a 91 f350 7.3 idi turbo...now it has a pretty rough idle to it but if you give it just a tad of juice it runs smooth...it always takes a few seconds to start warm or cold and seems a little hesitant when i stomp on it...any suggestions?? and its a 5 speed
Old Mar 20, 2012 | 08:59 AM
cowboyford16's Avatar
Injector timing is off
Old Mar 22, 2012 | 06:12 PM
Mike Roose's Avatar
and how would i fix that problem...remember its my first ford
Old Mar 22, 2012 | 07:56 PM
Take it to a diesel shop so they can time it.you have to have a special one for diesels
Old Mar 24, 2012 | 06:26 PM
sik88idi's Avatar
what are other symptoms of a bad timing???
Old Mar 30, 2012 | 01:25 AM
Mike Roose's Avatar
so the problem is the timing on the injectors??? would any of them being bad do the same thing? and its a 91 7.3 idi turbo....i recently found out that they didnt start putting the turbos in till 94...anyone know anything about this?? and it practically runs the battery dead before it starts when the motor is cold...even if its 60 out side
Old Apr 3, 2012 | 07:25 AM
Oklahoma diesel's Avatar
Banks ate and hypermax all made aftermarket turbos for these trucks, I have had both banks and the ate turbos. They are Gerry helpful if you tow, the 7.3 is gutless without one. You may need new batteries if they are dead befor you get it started, check all your cables they may be corroded
Old Apr 4, 2012 | 05:32 PM
4x4manonbroke's Avatar
before starting when it's been sitting in the a.m. check the fuel/water seperator, if its not full of fuel I would say you have a slight fuel bowl issue wich is common, replace with a 1 pc. filter/seperator, baldwin BF-1222 is one part number... I run them with out issue's. start there and keep us posted......
GarrettEvan
Jan 30, 2016 05:39 PM
Devon7.3
Sep 27, 2015 10:35 PM
Aug 3, 2015 09:20 AM
g.logistics
9
Nov 22, 2014 08:54 AM
Rx7man
Diesel Engine Conversions
Oct 15, 2014 04:00 AM
