Silencer Ring
Old Mar 10, 2012 | 10:30 AM
stuntmanmike's Avatar
Default Silencer Ring
I removed my air box to find that there is not a silencer ring in my 1995 6.5. I have done some research and found that there is a silencer ring in the 6.5 turbo but doesn't know how to remove I need help please. I have seen other 6.5's on youtube that have removed the ring or done a different mod to get the louder spool of the turbo
Old Mar 10, 2012 | 10:59 AM
great white's Avatar
The GM-x series turbos do not have a "silencer" ring like the Holset ones that come on the Cummins trucks. If you can find anything removable on this:
you're more than welcome to try and yank it out!
There is a "horse ****" style silencer, but it is just a resonance tube that comes off the rubber ducting:
If your truck has this, removing it will give a bit more , but it's not a silencer ring like you are thinking of. Mine still has it on and the turbo will howl like a banshee if I hit it's resonance point.
Other than that, swap in a high flow intake and filter and go to a 3" down pipe, 4" exhaust and a glasspack style muffler.
A turbo master will also keep you into the boost longer and hit sooner than the stock vacuum system, so it will also make the turbo a little bit more...
They're never going to sound like a powerstroke or duramax with a custom turbo spooling up though.
Lots of the videos on youtube are guys running without filters or intake ducting for effect.
You can't run that way for long on the street or your engine is gonna........
Old Mar 10, 2012 | 01:06 PM
Originally Posted by 617.95
The best airflow option is to upgrade from the flat panel filter to the later (1997+ I believe?) housing that uses the Fram 8037 filter.
That would be what is referred to as the K47 RPO option code.
Not all trucks got it so you can't just go by year. It came with the 8600 GVWR trucks or if it was special ordered.
S&B has a better flowing box than the K47, but it isn't cheap and it won't do a lot for "whistle".
The K47 is also not that easy to find anymore, most 6.5-ers are wise to the upgrade and have scoured most of the scrappers. Not to mention, a lot of these truck have gone to the crusher by now.
Expect to pay 100-150 for a complete box if you manage to find one...S&B was 299 last time I looked.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
Rclemson
Ford Powerstroke 2011-Up 6.7L
Jul 26, 2015 04:10 PM
CumminsAtYa
Mar 28, 2015 06:36 PM
detroitdiesel idi
Jan 2, 2015 02:07 PM
tabascom16
For Sale
Nov 28, 2014 01:48 PM
