New 1995 cummins 12 valve owner
Hey hows it going everyone. I am a new owner i just bought a 1995 cummins turbo diesel. Im just wondering is there anything mantience wise i need to look out for or anything i need to fix before it ruins the truck it only has 266 thousand miles on it and runs good its 2 wheel drive. If anyone could give me a list or suggestions of what i should check or fix to make it last forever let me know.
first of all, KDP, also known as the killer dowl pin. cheap fix, but can cause expensive damage. do a google search and there will be all kinds of information.
also, first thing I do when I get a new truck is change the oil, oil filter, and fuel filter. is it auto or manual?
Thanks also if i want to add upgrades such as bigger turbo or high horsepower injectors do i need to upgrade anything along with those upgrades. Im new so I'm just hoping to upgrade it a little bit put some moto metal wheels on it and drive it everyday!
If you're looking for more power, the first step would be to modify the fuel plate and AFC on the injection pump. Do you a search on Google and you should find plent of info on that.
Some must haves to go along with any perfomance upgrade is better flowing exhaust and air filter, gauges, and tranny upgrades to handle the power. Is it auto or manual?
It is a automatic truck ... I'm looking to do performance upgrades and also to put new wheels and tires on it so anyone who can give me suggestions on what to do let me know! or what wheels look best what tires work best for on and off road and what size wheels and tires all that stuff thanks!
Hey Everyone- My apologies for delay. I know more involving the engine and it has a 5 lb. reading on cylinder nearest firewall from compression test. I sure wish I knew of an honorable and fair diesel Mechanic/shop in Central Florida. I'm guessing its a rebuild plus machine shop on heads? I'm a Gulf War Vet just trying to get this truck moving for cross country use/work. Please advise.
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
