Fummins Transmission question
Old Jan 30, 2012 | 11:27 AM
IHWelk49's Avatar
Default Fummins Transmission question
Getting ready to start working again on my fummins. Have a 01 24v P-Pump motor. Ran numerous ideas through my head about which transmission to use. Have thought of going with a BTS E4OD, a 47rh, or NV4500 or NV5600. Wanting something with little to no electronics which had me settled on the 47rh or the 5 or 6spd. What kind of power can the 47rh handle if built right? When I bought the engine it had an adapter for the auto on it wouldve been for the 47re is that same bolt pattern as the 47rh?
Old Jan 30, 2012 | 01:39 PM
cumminsf150's Avatar
i vote for the nv4500, i would stay away from a 5600, just because they are so expensive and harder to repair. 4500 will bolt up with stock parts, and they are tough, all the horror stories about the fifth gear nut, at least the ones i have seen torn down, are usually caused by the driver overloading the truck. just because a cranked up cummins can haul a freightliner on a flatbed, dosent mean you should...
Old Jan 30, 2012 | 05:29 PM
Oil Field Trash's Avatar
NV4500! all the way! thats whats in my Chemmins '72 chevy with a p-pump 12v
Old Jan 30, 2012 | 10:13 PM
EasternAggie's Avatar
If you want to be really competitive in drag racing, go with a built auto, otherwise an NV4500 gets my vote.
Old Jan 30, 2012 | 10:41 PM
deck60's Avatar
nv4500 gets my vote also and for the fifth gear fix do this NV4500 Transmission 5th Gear Repair
Old Feb 6, 2012 | 09:59 AM
IHWelk49's Avatar
Well picked up a 47rh with tcase for a good price so will tearing it down and rebuilding the auto. Also does anyone have some pics of motor mounts they fabricated themselves? Would rather make my own instead of paying for them.
Old Feb 6, 2012 | 05:33 PM
deck60's Avatar
http://s1125.photobucket.com/albums/l582/deck60/ford%20cummins/
there are some pictures of my motor mounts in there
I used the motor mounts off a 2000 24v they let the engine sit lower
I used 12x12 3/8 plate steel for bottom the uprights are 4" x 1/2 metal set it in tacked it in place marked my holes and you are done the rear cross member I had to cut and drop it 1 1/2" for clearance but I am running a nv4500
Old Feb 6, 2012 | 07:55 PM
IHWelk49's Avatar
thanks for posting the pics. I got a set of 24v mounts from a part out i am going to make work coming, but if the dont I will be referencing to your pics.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Nov 16, 2014 05:14 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
