boost elbow
Old Jan 23, 2012 | 05:48 PM
ebbtide357's Avatar
Default boost elbow
1999 automatic just installed the edge ez does my truck have a boost elbow? and will it help to install if it does?
Old Jan 23, 2012 | 06:01 PM
RollinCoal99's Avatar
yes installing an edge adjustable boost elbow (like $30) will increase the amount of boost your turbo creats by choking waste gate pretty much. you can adjust how much boost you want
Old Jan 23, 2012 | 06:44 PM
H.R.D's Avatar
IIRC autos have an HY-35 this means you will have to get a j-hook to help keep the wastegate closed.
http://www.dieselperformancedb.com/cummins-j-hook.html
http://www.tstproducts.com/browsepro...-Assembly.html
Old Jan 23, 2012 | 07:50 PM
dolla_hite's Avatar
is the hole in the boost elbow suppose to be smaller or larger than the stock one?
Old Jan 23, 2012 | 08:01 PM
ebbtide357's Avatar
i have a hx 35 i think i see the elbow
Old Jan 23, 2012 | 08:12 PM
Wirtzy's Avatar
the boost elbow thru hole will be way smaller than the stock one. stock one looks just like a 3/8 pipe tap elbow with the other end barbed to bit on the hose and can easily pass thru a large amount of air and the one from edge has a really small hole in it, over half the size of the stock
Old Jan 23, 2012 | 09:54 PM
H.R.D's Avatar
Your right they didn't start to put hy35s in until 01. So yes install the boost elbow.
Sent from my DROIDX using Tapatalk
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
somarillw
Dec 4, 2014 12:37 AM
joshkhouse80
Nov 21, 2014 01:17 AM
