Silencer ring in the stock turbo?
Old Jan 23, 2012 | 04:43 PM
Smokey99's Avatar
Default Silencer ring in the stock turbo?
I'm new to these forums and have heard about removing the silencer ring what will it gain or loose and how would I go about doing it?
Old Jan 23, 2012 | 05:34 PM
holset cummins's Avatar
you most likely wont gain any hp or more boost but it will make your turbo a lot louder in the cab. to do this, you have to remove a snap ring inside your turbo housing. a really small flat tip works good, and wonce the snap ring is off, the silencer ring slides right out.
i like it out because you can really listen to your turbo.
Old Jan 23, 2012 | 06:01 PM
Oliver Green's Avatar
He is correct its so u can hear your turbo more and you can also put a cone air filter on to hear it even more
Old Jan 23, 2012 | 06:06 PM
Smokey99's Avatar
Ok is it on the intake side of the turbo?
Old Jan 23, 2012 | 06:09 PM
Devon527's Avatar
Yes its on the intake side, just undo the boot and you will see the ring and snap rings holding it in mine was out before I bought my truck
Old Jan 23, 2012 | 06:24 PM
Smokey99's Avatar
Thanks guys turns out mine was already taken out too
Old Jan 24, 2012 | 12:39 AM
jake0789's Avatar
Absolutely no power gain whatsoever, just noise difference. I did as stated before, put on a spectra cone filter, only problem is with that, living in the country, I have to buy a new one every month or so. But it allows a pretty quick turbo spool.
Old Jan 25, 2012 | 06:07 PM
Cummins2000's Avatar
yep if you get a bigger filter (BHAF or aftermarket) whistle will be very noticable. No noticable power increase on a stocker.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
Rclemson
Ford Powerstroke 2011-Up 6.7L
Jul 26, 2015 04:10 PM
CumminsAtYa
Mar 28, 2015 06:36 PM
n2brk
Feb 21, 2015 09:05 AM
tabascom16
For Sale
Nov 28, 2014 01:48 PM
