brake issues
Old Nov 15, 2011 | 08:11 AM
92idi's Avatar
Default brake issues
for the past day every few times i hit the brake the pedal goes about halfway before it grabs, if i let off and hit them again they are fine and hold pressure... not loosing brake fluid at all so im not sure whats causing it... oh btw 92 f250 7.3 idi HELPPP PLEASE
Old Nov 15, 2011 | 02:33 PM
gradyc's Avatar
Most likely air in the lines. You probably need to bleed the brakes.
Old Nov 15, 2011 | 06:09 PM
daveO's Avatar
Could be air in the lines, I would def check that first. Could also be an excessively worn master cylinder allowing fluid to leak by the pistons.
dwmeehan
Jan 29, 2025 12:13 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
Mat Zimmerman
Dec 8, 2014 11:37 PM
yams
Nov 29, 2014 09:25 PM
