Smoke out
Old Nov 6, 2011 | 09:06 PM
Kageni's Avatar
Default Smoke out
I have a 2001 7.3L F250 with 200,000 miles that is not doing well. It smoking BAD when hot and has a clicking sound. It's throwing codes P0308, P1211, and P1670. It just has code P0308 before, cylinder 8 misfiring, but I was driving it today and under acceleration it started doing the clicking and smoking randomly. It now smokes enough to not be drivable but get's worse when it's hot. Where should I go from here?
Old Nov 6, 2011 | 10:18 PM
OceanDiesel's Avatar
Here's a sticky that will help you out. https://www.dieselbombers.com/ford-p...d-2-codes.html
Old Nov 6, 2011 | 10:35 PM
Devon527's Avatar
Is it white smoke? Might have a injector o-ring that cracked. My buddy has a 95 and his did that last week, clicking and mass amounts of white smoke. New o-rings and it all went away. hope this helps
Old Nov 7, 2011 | 12:57 PM
Kageni's Avatar
I'll try and replace the O-rings, if it's just that then I will be very happy. The sticky indicated that the only cause of a P0308 code is mechanical failure of the motor, is this true?
Old Nov 7, 2011 | 03:10 PM
95powersmoker's Avatar
It might be worth taking those injectors out and sending them off to a place like Rosewood to have them flow tested. Also might be worth while to get a compression test done on that motor..
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
