egt's WAY TO HOT
Old Oct 31, 2011 | 09:27 PM
twinturboedcummins's Avatar
Default egt's WAY TO HOT
my egt's are hitting 1500-1600 wihtout a problem and it gets there within a second or two, what can i do????? for mods i have twins, holset hx40 over a garret ht3b,#10 plate,sdx 5x.014 injecters,5" turbo back exhaust,pump tuning,60lb valve springs,4gsk,boost elbow,arp studs.
has no problem hitting 70psi on the boost but cant keep in the throttle any suggestions???? thanks
Old Oct 31, 2011 | 09:36 PM
Red_Rattler's Avatar
High Tech Redneck
Take away some low boost fueling, how much smoke at wot? Can the turbos clean it up? Might have to remove some fuel all the way around.
Old Nov 1, 2011 | 10:12 PM
i think i need to take away fuel all the way around. the turbos clear up the smoke once they spool up and it can be driven totally clean just normal driving but as soon as i lay into the throttle egt's skyrocket. i actually purchased the truck the way it sits and really dont know how to turn the fuel down. back off the smoke screw? turn the starwheel? im lost any help would be greatly appreciated
oh and at an idle of white-ish grey smoke like its to rich or the injectors need to be shimmed or something like that??
Last edited by twinturboedcummins; Nov 1, 2011 at 10:12 PM. Reason: Automerged Doublepost
Old Nov 2, 2011 | 02:33 PM
dennhop's Avatar
For just a quick reference, might try taking the starwheel, tightening it up a little bit, so that its exactly full forward at 60-70 psi, and then taking the smoke screw and setting it so that it barely touches the AFC arm when at rest. It's not the most scientific method, but might get you an idea of whats going on and where to start digging next.
Old Nov 2, 2011 | 03:31 PM
Farmboy 2.0's Avatar
Also do you know what your timing is set at? To much timing will make the truck run hotter as well
Old Nov 4, 2011 | 06:02 AM
I have no idea what the timing is advanced to. Is there a way to check that?
Old Nov 4, 2011 | 08:53 AM
You will have to have a 12 valve timing kit to check it. Becuase I dont think there is any other way. Also are all your intercooler boots in good shape?
j1004ss
9
Dec 23, 2021 02:59 PM
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
Dustin M
Mar 17, 2015 08:59 PM
