2001 dodge cummins
Old Oct 26, 2011 | 11:45 PM
dgarrett's Avatar
Default 2001 dodge cummins
Need some help with this truck died while I was driving it and wouldn't start again it shot codes where the odometer is the codes where 0462 and 0463 and 0122 and 1693 if anyone can help I would be greatfull
Old Oct 27, 2011 | 09:33 PM
cummin_un_glued's Avatar
FormerVendor
P0122 is a TPS code and i'm gonna say thats your problem, 0462/0463 are fuel level sending unit codes...does your guage work? and 1693 means you need to hook it to a good scan tool because it has another code
Old Oct 27, 2011 | 09:49 PM
dgarrett's Avatar
Yea the gauge works and the book I got says that this truck doesn't have a TPS on the manuals wat is it calling the sending unit I put a new fuel module in but don't have power to the plug I don't have a clue wats wrong
Old Oct 27, 2011 | 10:10 PM
FormerVendor
yes it does have a TPS its inside that box that is held onto the head with 3-13mm bolts and there is a plug on the bottom side
Old Oct 27, 2011 | 10:48 PM
dgarrett's Avatar
So its up by the where the throttle cable is mounted on the block and if I buy a scan tool and clear all the codes and it throws the same code that's probly wat it is
Old Oct 28, 2011 | 05:39 PM
FormerVendor
yeah i'm gonna say with those codes and it being dead that is the problem
Old Oct 28, 2011 | 05:53 PM
dgarrett's Avatar
So I bought a code reader today and cleared the codes and now its throwing 0251 0252 1688 wat do I do now
Old Oct 28, 2011 | 09:31 PM
FormerVendor
1688 - "Internal Fuel Injection Pump Controller Failure"
could be new vp44 time
clear them again and see if it comes back if so its time for a pump
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Shun70
Sep 20, 2015 10:52 PM
raude1
Apr 13, 2015 03:38 PM
rschriek
Jan 26, 2015 07:30 AM
kamwil54
Nov 2, 2014 08:48 PM
