Anybody recognize this underdash wiring?
Old Oct 23, 2011 | 04:36 PM
95powersmoker's Avatar
Default Anybody recognize this underdash wiring?
I was looking over my new purchase today and found some wires under the hood that were cut and went to nothing... I followed them back to this switch. The two green wires go from this switch to a relay under hood. Then from there one green wire is grounded and the other one goes through a fuse to nowhere. It was cut and the end was under the drivers side battery. The blue wire seen in this photo is spliced into the wires coming from a connector on the accelerator pedal. Then it follows the two green wires out to the relay underhood. I didn't get any power to any of these three wires except with the key on. With the key on my voltmeter showed .05 volts with the switch on or off.
So does anybody recognize it? I can't think of what it might be for and why it is tapped into the wires from the accelerator pedal...
Old Oct 23, 2011 | 04:52 PM
fordornothing's Avatar
could have been from a old alarm system or if the one wire went to the accelerator pedal. maybe it was so you couldn't drive any where... my moms mustang has something similar but i don't know what it is. or it might have something to do with the day time runing lights. but not likely...
Old Oct 24, 2011 | 07:39 PM
CSIPSD's Avatar
If I had to guess it was an old school exhaust brake. The only time the brake would turn on is when you were off the pedal.
Old Oct 25, 2011 | 07:04 PM
Ding Ding Ding... I traced it some more today and there are two wires running straight to the EBPV...
Old Oct 25, 2011 | 07:13 PM
hmmm. i'll have to see if i can do that.
Old Oct 25, 2011 | 08:13 PM
CSIPSD's Avatar
Its easy to do... I had a nice one on my 97 OBS and a really slick one from SP Diesel on this truck when I first got it.
If you have an auto you need to have the TC locked to really have a good brake.
Not an issue with a 6speed.
Old Oct 26, 2011 | 06:33 PM
well mine is the 6 speed. when i did the brake on mine, i follwed the writeup on swamps website. i just don't have it so it comes on when you hit the brakes. so with hooking it up to what looks like the red wire in the picture. when you let off the accelerator does it put power to this wire?
that is a slick setup from SP Diesel. they got all sorts of cool stuff
Last edited by fordornothing; Oct 26, 2011 at 06:33 PM. Reason: Automerged Doublepost
cumminspwr11
12
Oct 17, 2021 03:50 AM
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
Mike H
Nov 25, 2014 03:13 PM
