broken screws in injection pump cover
Old Oct 19, 2011 | 11:09 AM
jedibob's Avatar
Default broken screws in injection pump cover
I was removing the 3 small flat head screws from the injection pump cover. 2 out of the 3 broke off, about 1mm form the base. Any suggestions on how to get these out, or should I replace the IP?
Robert
1984 GMC K20 6.2L diesel 4x4
Old Oct 19, 2011 | 11:55 AM
anarchy61187's Avatar
Ouch, try a reverse drill center punch the screw and use a reverse drill the size you would need to rethread and retap for the screws. Its not a cake walk and will take a bit of skill, just be careful and take your time and if done properly you will save your self some money. I say to use a reverse drill because sometimes you get lucky and it pulls the screw out but you can use a regular drill bit if you choose.
Old Oct 19, 2011 | 03:14 PM
jdozer's Avatar
Happened to me to. Drilled and retapped the holes. A touch of form a gasket on the mating surface and its good as new
Old Oct 19, 2011 | 03:30 PM
I had to do the samething to a distributor on an 87 civic when replacing the cap and rotor. $300 for a new distributor from Japan is not an option because the car isn't worth that much.
HardLuck
Jun 24, 2015 08:04 AM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
