ABS light on?
Old Oct 8, 2011 | 06:44 PM
NeedinMoPWR's Avatar
Default ABS light on?
My ABS light turned on all the sudden. No hard breaking, not towing a trailer nothing, just got in my truck the next week and it was on. Any ideas? when i turn the key on but dont start her and push the breaks all the way to the floor it turns off but about 1-2 seconds after i let off the breaks it turns back on
Old Oct 8, 2011 | 06:57 PM
fordornothing's Avatar
on the front axle, there is a sensor on the hubs. check those. it might have came un plugged.
Old Oct 8, 2011 | 07:10 PM
dont see one... everything looked plugged in I those have 3 lines running to each front wheel and there all plugged in... then again im not sure what im looking for and exactly where do i have to take the tire off or turn them to see or...
Old Oct 8, 2011 | 07:15 PM
well if they seem tight then it's fine. one is a brake line, vacum line, and a wire for the ABS. under the dash. check the brake switch on the brake pedal. or the plugs on the master cylinder.
Old Oct 8, 2011 | 07:26 PM
will do. thanks buddy
Old Oct 8, 2011 | 07:46 PM
any time.
Old Oct 10, 2011 | 08:39 PM
so i checked my sensor/connector deal by my break pedal my master cylinder is full and all the lines around the wheels are good and it still on... any other ideas?
Old Oct 10, 2011 | 09:14 PM
Rj91jeep's Avatar
The ABS light will throw a code. Go have the code checked and it will tell you what the problem is. Last time mine came on, it was the ABS sensor on the rear axle went bad.
Old Oct 10, 2011 | 09:40 PM
thanks man
Old Oct 11, 2011 | 11:22 PM
flathead jack's Avatar
jack up the front wheels see if they are loose could be wheel bearings wore out and metal on the sensors
Radioking1777
Jun 9, 2015 04:13 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
ValleyF250
Nov 1, 2014 07:56 PM
