Fuel pressure
Old Sep 20, 2011 | 11:33 PM
tower_ofpower's Avatar
Default Fuel pressure
I drilled and tapped my AFC delete pump top so I could keep an eye on my fuel pressure. With the engine running I hooked the gauge up and the needle was bouncing between 20-60 psi. Now I know that's extremely high for a VE. 13-15 being the sweet spot. I have a better quality gauge and I'm hoping that's all it is. Other wise I'll have to find a snubber. My question I guess, is that supply pressure to the pump from my AD should technically be case pressure correct? My pressure port is tapped into the return galley before it hits the banjo bolt.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
