Which Starter for my 7.3 IDI
Old Sep 1, 2011 | 10:10 AM
89crew's Avatar
Default Which Starter for my 7.3 IDI
Well I am brand new to the diesel world. Last month I bought an 89 crew cab with a 7.3 IDI. Have taken it on a few trips now and it has run great. Other day I went out to start it up and it was cranking great, then like something broke while cranking, it began cranking slow. She does fire up, just doesnt spin over too quick, so it takes a while to get it to fire. After cranking for 5 seconds, it starts to crank faster. So I pulled out the cables, batterys and starter and will be replacing them all, as they all look pretty well used up.... My question is, which starter will handle the abuse this motor puts out in these MN winters. Thanks in advance for any advice....
Josh
I pulled the non gear reduction style out (I believe its called Mitsubishi style), am contemplating putting the gear reduction style in it (nippondenso style)..... Would I have to change anything to do this, and would it be beneficial? Thanks again
Old Sep 1, 2011 | 03:08 PM
Countrykenrs's Avatar
Default 7.3 offset gear reduction versus planetary starters
All of the 7.3 starters I have seen utilize gear reduction to multiply torque. I have had three of the offset gear reduction starter tail stock bearings fail because of the offset loads. I have had no problems with planetary gear reduction starters I started using once I discovered they existed.
Ken
Old Sep 1, 2011 | 08:03 PM
DieselCrawler's Avatar
get the nippo one. much better. also if u plan on cranking alot, get one from advanced. lifetime warrenty.
Browe347
Dec 11, 2016 02:59 PM
Nick91
May 11, 2015 11:52 AM
Toms73
Mar 23, 2015 08:31 PM
honda89
Dec 27, 2014 06:19 PM
Browe347
Sep 30, 2014 11:35 PM
