simple ac compressor wiring question
Old Aug 25, 2011 | 08:12 PM
F350Fummins's Avatar
Default simple ac compressor wiring question
Here's the deal guys I'm getting to wiring up the compressor on my 92 fummins and - am bypassing the stock wiring because it was all messed up, anyways I'm putting a toggle switch to turn the compressor on and off and I'm hearing that you have to put a relay in and run the power threw the pressure switch and I should be good to go?
Old Aug 26, 2011 | 06:41 AM
cumminsf150's Avatar
fuse - relay- low pressure switch - clutch, as long as the switch is a high/low switch, but im sure it is as that year only has one switch (that i know of).
Old Aug 26, 2011 | 10:37 AM
Thanks, what size wire, fuse, and relay would you recomend?
Joracing3
Sep 10, 2016 05:28 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
scd2747
Oct 7, 2014 02:56 PM
