Diesel conversion for a 1970s GMC RV
Old Aug 13, 2011 | 11:23 PM
Slam's Avatar
Default Diesel conversion for a 1970s GMC RV
Hey folks,
First time poster here, long time forum member at the VW TDI club forums. They can't help me with this one though. =)
I'm totally obsessed with the mid-70s GMC RVs. The only fatal flaw is that they never came in diesel! I know, right? GMC motorhome - Wikipedia, the free encyclopedia
They seem to be loosely based on the Oldsmobile Toronado chassis and use the Toronado/Eldorado Turbohydramatic 425 automatic transmission.
Would it be possible to drop a Cummins turbo diesel into this rig? What exactly would that take to install?
If not a Cummins then what else? I am fond of the TDI motors but stock HP on the GMC RV looks like it was around 150+ and my TDI puts out only 90. =) I do have a Chevy PD van with an detroit diesel V8 but I think it's crap. =)
Old Aug 14, 2011 | 04:40 PM
No Sparkplugs's Avatar
Keep in mind the Olds 455s put out over 400ft/lbs. Some careful measuring will be needed, the 4BT cummins is a fairly long motor (~31" long overall).
Old Aug 15, 2011 | 12:34 AM
Slam's Avatar
Is the a handy reference chart somewhere for Cummins motors and their sizes?
Old Aug 18, 2011 | 10:48 PM
u2slow's Avatar
The 6BT is 36" long... plus whatever you add on for adapter or flywheel housing.
Old Aug 19, 2011 | 12:35 AM
Slam's Avatar
"adapter or flywheel housing."
It seems like there's a number of stock adaptors. Is there a list anywhere of adaptors and housings?
Otherwise... does it sound like I will be fabricating my own for this RV?
Old Aug 22, 2011 | 05:43 PM
u2slow's Avatar
I am aware of adapters for Chevy, smallblock Ford, whatever Dodge used, and SAE types (i.e. round from medium-duty trucks).
One of my previous employers had a motorhome like yours. I have a pretty good memory of how they're put together. Basically the torsion-bar setup from the '70's Toro/Eldo platform. I would stick with a GM engine for size, weight, and not destroying the drive system. Chevy engines can be adapted to the Olds pattern with a simple steel plate (4 of the 6 holes are the same). A turbo 6.2/6.5 diesel should do okay with the 3.07 final drive.
If you really want to Cummins it, you could run a 4wd trans and t-case with a Dana 60 front axle. Some aftermarket companies build these for some bus and box truck applications where a low floor is desired. Just thinking outside the box
Cab Chassis |
Old Aug 23, 2011 | 01:29 AM
Slam's Avatar
u2slow, thanks for the info. I like your thinking outside the box, that's an interesting tangent, that maybe the trans can be replaced as well.
I own a 1993 NA 6.2 in a Chevy P30 van and I can't say I'm very impressed. It does not seem nearly as well-engineered as my 1996 TDI for instance. I've never owned a Cummins but I hear they are bomb-proof in terms of reliability and power-to-weight. Is this just a myth? Is the turbo 6.2 really comparable to a Cummins?
I feel confident I could handle a conversion if it's a matter of buying available adaptors. I'm not sure how up I am for fabbing my own adaptor plates. Engine mounts I can manage, maybe. =) Fabbing though is a whole new world to me.
Old Aug 24, 2011 | 01:35 AM
u2slow's Avatar
A 6.2/6.5 doesn't hold a candle to a 6BT. I'm really only suggesting it as a means of keeping the Toro/Eldo suspension & drivetrain intact.
If I was intent on a Cummins fwd situation, I would probably use a Dana 60 (spring-under & airbags?), trans of your choice (think OD trans), and a NP205.
I remembered there's CV-jointed axles for the Dana 60 available from a company called RCV.
Diesel Guy23
Oct 18, 2015 11:41 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Radioking1777
Jun 8, 2015 10:26 PM
Mart
Jan 10, 2015 03:28 AM
Jut1915
Oct 15, 2014 08:13 AM
