waste gate adjustment
Old Jul 16, 2011 | 05:55 PM
shorty2tall's Avatar
Default waste gate adjustment
Ok so I've only ever seen 20-21 max with the red wire off the waste gate. And I think it's the waste gate. Which way do I turn the adjustable part in or out for more boost?
Had anyone used the banks or bd ones?
Are they worth it?
Old Jul 17, 2011 | 10:41 AM
CSIPSD's Avatar
Didnt you just install a 38R? The wastegate rod needs to be shortened to hold closed longer. 38R's is very easy to adjust.
I had a turbomaster WG rod which worked great! Easy to adjust and took the computer out of the equation!
http://www.dieselsite.com/index.asp?...ROD&ProdID=875
If your running a stock turbo still then the easiest way is to stick some washers between the WG canister and the housing.
Old Jul 18, 2011 | 01:51 AM
Ya it's a 38R, so pull the turbo and cut the thread some? Until I get the other adjustor?
Patrick
Old Jul 18, 2011 | 05:04 PM
How much should I cut off? And what's the best thing to use to cut it?
Patrick
Old Jul 18, 2011 | 05:57 PM
CSIPSD's Avatar
Wooooooooh there buddy. Dont cut anything. Just shorten it. You simply need to loosen the jam nut and shorten it 1-2 turns. Then hook it back up. You dont even need to pull the turbo to do this.
Old Jul 18, 2011 | 07:10 PM
oh ok i thought u meant shorten but cutting ok. is it easy to do on the truck?
whats the easiest way to get the c-clip or jesus clip off? im having issues getting it off. and what size is it if i lose it?
Last edited by shorty2tall; Jul 18, 2011 at 07:10 PM. Reason: Automerged Doublepost
Old Jul 19, 2011 | 09:53 AM
CSIPSD's Avatar
I always just uses a pair of needle nose pliers to push it off and tie a piece of dental floss on it before you try and remove it.
Old Jul 19, 2011 | 01:19 PM
Ya a guy in another forum said just get a pair of vice grips on the shaft piece and turn it the opposite way u would turn the end worked a little so far got 21 now Need to go turn it more today. But I'm getting a used diesel site turbomaster thing for cheap!
Patrick
Old Jul 19, 2011 | 02:46 PM
jessh's Avatar
On my edge CS it has a waste gate percentage gauge. It shows it 98.8% all the time and once I start to reach 20 to 23 lbs of boost it starts to open up. I read where you can stick washers in the stock one to tighten it up. Do you think that would close it up or if its closed and that's just what the chip shows?
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
vin_diesel
Mar 1, 2016 01:43 PM
six speed
Sep 14, 2015 09:19 PM
timmyd
Jun 8, 2015 11:35 PM
carid
Diesel Bombers Sponsors
Jan 19, 2015 08:30 AM
