no boost
Old Jul 11, 2011 | 05:23 PM
diesleguy's Avatar
Default no boost
ok so were coming home from the lake, pass a trailer fine but after that my gauge reads 0 and it wont spool and make the truck go real fast anymore. i checked all the hoses and cant find a leak so i figure the gauge should atleast read something, it wont smoke in 4th or 5th anymore ether
please and thanks
its a 98 12 valve
Old Jul 11, 2011 | 10:23 PM
daveO's Avatar
You may want to take the air filter assembly off and make sure your turbo spins freely and doesn't have excessive play.
Old Jul 11, 2011 | 10:27 PM
diesleguy's Avatar
ive done that i can still hear the turbo whistling but im thinkin the line that pushes air into the afc has popped off or something like that?. its bien to raininy to go out there
Old Jul 12, 2011 | 01:19 AM
daveO's Avatar
That's definitely a possibility.
Old Jul 12, 2011 | 01:46 AM
godblessmud's Avatar
Blow an intercooler boot?
Old Jul 12, 2011 | 07:53 PM
diesleguy's Avatar
k so everything looks like it should be working all my intercooler boots are connected (if they had just a small leak wouldnt i still read some boost?) the wastegate is pluged and the steel line running from the accuator is still connected to the T on the afc housing
any idears??
please and thanks
is my next step test the accuator with compressed air?
Old Jul 12, 2011 | 10:50 PM
daveO's Avatar
It depends on the size of the tear. If it's a small pinhole, then yes, you should still be seeing at least some boost. You could build yourself a pressure tester and check the whole system.
Here's a link on how to build a pressure tester.
https://www.dieselbombers.com/dodge-...tructions.html
Old Jul 13, 2011 | 10:36 PM
diesleguy's Avatar
i will do that. i sure hope its a busted boot cuz i have no other ideas what it could be
thanks for your help
how big are we talkin of a hole to lose all boost pressure
Old Jul 20, 2011 | 10:45 PM
diesleguy's Avatar
it was a lower passanger boot a pinsize hole were the boot had bein rubbing on the lower rad hose
Old Jul 21, 2011 | 11:11 AM
daveO's Avatar
Glad you found it.
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
