Front Oil Seal
Old Jun 23, 2011 | 06:24 PM
Sandman8105's Avatar
Default Front Oil Seal
I believe I have found a new problem in this saga of making this thing right. Found oil leaking around the area of the front seal. Can anyone tell me how hard this would be to replace it and how I would go about doing it?
Thanks,
Sandman
Correction everyone. Looks like an oil pan gasket leak. Besides draining the oil and pulling the pan, is it very tough to do?
Thanks,
Sandman
Last edited by Sandman8105; Jun 23, 2011 at 06:24 PM. Reason: Automerged Doublepost
Old Jun 23, 2011 | 09:35 PM
DieselCrawler's Avatar
very hard to do it in the truck. engine needs to be picked up to clear the pan from the oil pickup. also do not buy a gasket. just use GOOD rtv. from the factory all it has is rtv. using a gasket will seal it up, but only for a few miles. i recomend Right Stuff RTV.
Old Jun 23, 2011 | 10:10 PM
Permatex red? Will that seal it? Give me a shout if you can. My number is posted. Thanks D.C. I need ALL the help that I can get.
Trying to make her right. I appreciate all the help that I can get.
Thanks again,
Sandman
P.S. 99.9% sure that it is the oil pan gasket.
Old Jun 24, 2011 | 04:58 PM
you can use that, but make sure both surfaces (block and pan) are CLEAN before installing.
Old Jun 24, 2011 | 07:50 PM
Cool. Thanks. I was visiting Bud Light last night when I read your reply. I will take the gasket back. Don't use a gasket even if you permatex both sides?
Thanks,
Sandman
Will I have to raise it up as high if I drop the oil pick-up tube?
Last edited by Sandman8105; Jun 24, 2011 at 07:50 PM. Reason: Automerged Doublepost
Old Jun 24, 2011 | 11:50 PM
no, but it will be very hard to get it bolted back up with the pan in the way.
and dont use the gasket. .
how i would do it.
drain oil and coolant.
unhook fan shround and pull rad out, for clearance reasons.
unbolt motor mounts.
use engine hoist and pick motor up as far as you can.
loosen pan and see if it clears. if it doesnt, might have to undo trans mount and slide it forward some so the engine can come up more.
Old Jun 25, 2011 | 12:03 AM
Sounds like I should just pay a shop to do it. Thanks D.C.
Old Jun 26, 2011 | 12:09 AM
bah, it isnt to bad of a job. maybe 3-4 hrs max.
Paul08
Ford Powerstroke 08-10 6.4L
May 9, 2021 11:01 AM
makuloco2000
Dec 20, 2015 11:19 PM
soco
Jul 27, 2015 06:06 PM
cutthroatxxx
May 18, 2015 11:10 AM
coors_man_2005
Dec 15, 2014 10:23 AM
