White smoke?!
Old Apr 26, 2011 | 09:35 PM
rhurley's Avatar
Default White smoke?!
My truck sat for 2 days and today when I started it, it was a little hesitant and puffed out a small cloud of white/greyish smoke.
Is this a sign of something?? Or should I worry about it? The truck is still bone stock
Old Apr 27, 2011 | 12:07 AM
95powersmoker's Avatar
You will get a little more help posting in the Duramax section...
Old Apr 27, 2011 | 01:56 AM
2500HeavyDuty's Avatar
anything out of the ordinary, like oil smells funny. or low coolant smells funny?
Old Apr 27, 2011 | 09:28 AM
rhurley's Avatar
no not that i see. oil looks fine. coolant doesnt smell wierd.
Old Apr 27, 2011 | 09:37 PM
BriteWhiteRam's Avatar
I would get your injector ballance rates checked out... might have one or two out of spec... pushing more fuel into the cylinders than should be
Old Apr 28, 2011 | 05:06 PM
rhurley's Avatar
****. haha It puffed out i nice cloud this morning. Do dealers charge to get rates checked?
If the rates are bad, what am i hurting? does this mean i need to change injectors?
I am very competent with gas motors. this is my first diesel. Just looking for some info. Thanks
Old Apr 28, 2011 | 06:35 PM
regular rate for diagnostic fee
Old Apr 28, 2011 | 08:54 PM
get it checked out first, then you can go from there
if the balance rates more than 4+/- in park or 6+/- in gear then you probably have a bad injector, if thats the case then yes you need to replace them, you can burn a piston if you run it too long like that, you could also be making oil, I would check your oil and see if it smells like diesel or not
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
