Hard STart and white smoke at start up - even when warm
Old Apr 25, 2011 | 12:39 PM
Rosco's Avatar
Default Hard STart and white smoke at start up - even when warm
ok so drove my truck to my inlaws yesterday and everything is dandy. Go to leave and when I start up i have a bit of a knock/ rough idle for maybe 5 seconds and TONS of white smoke. Did it again when i got home and tried again. Ran just fine all the way home. Pulled the smarty out and still did the rough start/idle just not as bad but with less white smoke. I pulled the codes and got the P0602 or something close to that(codes are wrote sown at home). It was about the fueling With non stock software. No . Cleard the codes and still the same problem. Where should I start??
Old Apr 25, 2011 | 02:02 PM
cummin_un_glued's Avatar
FormerVendor
I would start with the fuel control actuator on the cp3 make sure it is plugged in good if it is unplugged it will default to max rail pressure and over fuel...also if you have a pressure box take that off it could also be that the fca is sticking I have seen that a few times
Nm just seen its a vp truck sorry
Last edited by cummin_un_glued; Apr 25, 2011 at 02:02 PM. Reason: Automerged Doublepost
mattshow123
14
Mar 12, 2018 01:41 PM
Poppie5x
Mar 22, 2016 12:10 PM
Timglow546
8
Jun 3, 2015 10:13 PM
gator515
Jan 14, 2015 01:56 PM
Domrig13
Dec 12, 2014 01:24 PM
