Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
making boost tubes
Old Apr 20, 2011 | 11:00 PM
ironworker's Avatar
bulb making boost tubes
I m needing to make some new piping from turbo to the inter cooler and from there to the intake Any one have any good ideas on how to make and what to make them out of?
Old Apr 22, 2011 | 03:03 AM
bryson's Avatar
I have used mandrel bent exhaust pipe, and had great results.
Something like this.. Search Results for mandrel exhaust - SummitRacing.com
Just cut the pieces up and make the shapes you need. Make sure your welds are good too - pinholes in your welds will cause lots of headaches down the road.
Old Apr 30, 2011 | 07:01 PM
PowerstrokeConvert08's Avatar
did htis when I did an HE351 conversion, worked awesome
Old May 24, 2011 | 10:25 AM
Rogue Scottsman's Avatar
What did you convert from? I have an HX35 and thought about going to the HE351, maybe even doubling up on the stock with the 351. (thought about it, still doing research to see if will do any good!)
Last edited by Rogue Scottsman; May 24, 2011 at 10:25 AM. Reason: Automerged Doublepost
Old May 27, 2011 | 07:42 PM
cummin_un_glued's Avatar
FormerVendor
compounding the 351 and 35 will not do you any good, only thing it will do is increace your drive pressure and decrease your spoolup
you would be alot better off with the 351 alone
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
joshkhouse80
Nov 21, 2014 01:17 AM
offroad00
24
Oct 23, 2014 03:28 PM
