7.3 white smoke
Old Apr 19, 2011 | 05:36 AM
countryboy51's Avatar
Default 7.3 white smoke
hey guys i have a 01 7.3 with ts 6 position chip, 4 inch exhaust, and afe intake. other than that the motor is stock. it is blowing white smoke under acceleration and when i let off. not so much with cold starts or at idle. im thinking it is a bad injector or the turbo. ive also heard ppl say it could be a mat sensor. any input would be helpful. thanks.
Old Apr 19, 2011 | 09:20 AM
95powersmoker's Avatar
Does it go away fairly quickly? White smoke is normal on cold starts... It's just unburnt fuel. If it doesn't clear up, then you might have an issue.
Old Apr 19, 2011 | 10:53 AM
CSIPSD's Avatar
Try and get a wiff of the smoke... Could be oil, could be fuel, could be coolant.
Old Apr 21, 2011 | 12:25 PM
it doesnt smoke at idle or start up. it smokes during acceleration up to around 40 mph and also puts out alot when i let off from cruising at high way speeds. seems to be white and a little bit of a blue tint possibly. but it still runs fine with no rough idle or missing...which makes me think that its not a injector issue. my thoughts are that its the turbo...it does have 176000 miles on the stock turbo.
also it only seems to do this after its had a good chance to warm up...after 15 minutes of driving or so..its hard to get a whiff of the exhaust in the driveway cuz it will only smoke if i rev it up and its diffucult to run around the truck and get a whiff with the wind blowing like it is.
Last edited by countryboy51; Apr 21, 2011 at 12:25 PM. Reason: Automerged Doublepost
Old Apr 21, 2011 | 04:11 PM
CSIPSD's Avatar
I would agree its the turbo. You can remove the intake and check for excessive play and also remove the down pipe and check for oil or sludge build up from a leaking seal.
Old Apr 26, 2011 | 06:55 AM
i havent got the chance to pull off the intake and down pipe to take look at the turbo yet..should there be any play in the shaft? ....i have looked at some turbos online and the garrett 38r turbo seems to be a good route for the price. im not looking for big horsepower..but putting a stock thrust bearing turbo back into the truck isnt what i want to do. any thoughts?
Old Apr 26, 2011 | 10:28 AM
There might be some side to side but it shouldn't touch the housing. You don't want any in and out play.
38r is a great, inexpensive option for you.
Old Apr 26, 2011 | 02:45 PM
ok well when i get the chance to check out the turbo i will post what i find. i just hope that i dont spend the money on a new turbo and still have my truck blowin white smoke going down the road . but i cant really think of any reasons for the white smoke seeing how it doesnt miss or cut out or smoke at start up or idle. still runs great. it mists a little bit out of the oil filler cap but that seems to be normal..also gets great oil pressure. and i dont notice any lost coolant or coolant on the dipstick. so a leaky turbo seems to be my problem
Old Sep 8, 2015 | 08:59 AM
motocox_307's Avatar
did you ever figure out what it was? i'm having that problem now even after getting a new turbo.
Old Sep 8, 2015 | 06:21 PM
joebob3093's Avatar
Moderator
This thread is 4 years old....
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
mihilo
Sep 16, 2015 10:42 AM
motocox_307
Sep 8, 2015 09:09 AM
Domrig13
Dec 12, 2014 01:24 PM
