Fass pump
Old Apr 12, 2011 | 02:02 AM
RESILENT's Avatar
Default Fass pump
So my truck died on me again and a call to the shop they tell me fuel pump and they like the fass, but the tech tells me pump only and I am not sure if its in the tank or not. The tech also tells me I may need to do the new pick up tube. If the pump is outside should the replacement be pretty straight forward, also I like the platinum the tech said that all I need is the 90 gph not the 150.
Old Apr 14, 2011 | 01:04 AM
torqctd's Avatar
outside the tank....straight forward install.......you will need a drawstraw for pickup.......95 should be fine with no major mods.
Old Apr 14, 2011 | 07:17 AM
steved's Avatar
He should only need the draw straw if the pump is in the tank...I ran my FASS 180k through the OE pickup tube.
Old Apr 14, 2011 | 03:50 PM
torqctd's Avatar
Steved is correct. I thought 4.5' (Dodge)came with an in tank pump. Thought my 04 was the last model with behind the FF pump. Did you need to modify your old pump?
Old Apr 15, 2011 | 11:36 PM
RESILENT's Avatar
Cool thanks.
JoeyMiR
9
Feb 3, 2018 10:05 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
ramrunner01
9
Jun 4, 2015 03:34 AM
