6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Delete stock Fuel Housing
Old Apr 11, 2011 | 10:09 AM
Crazy's Avatar
Default Delete stock Fuel Housing
well had leak in fuel housing and get try playing around with and strated to thing what pain in the @ss it was change filter so post some pic what i have done now the filter that on it is not staying got one coming today with water drain on the bottom of it
Attached Thumbnails Delete stock Fuel Housing-6.jpg   Delete stock Fuel Housing-7.jpg
Old Apr 11, 2011 | 06:30 PM
goobs's Avatar
man i thought about doing that just this weekend since i had to take mine apart and clean it out and replace the lines going to and from it. then had to unbolt it again and move it over to replace the oil pressure sending unit.
Old Apr 12, 2011 | 09:37 AM
Crazy's Avatar
i like idear that i don't have climb on top engine no more change filter getting to old for that
Ya pic up that system at walmart where they sell boating stuff $28.00 with filter then $20.00 in fittings, clamps, and fuel line
Old Apr 15, 2011 | 01:11 AM
ssgstank's Avatar
I saw that today wile I was killing time waiting for my tires to get mounted. Iam gonna change my lift pump so I might have to do this mod wile I have the fuel sistem opean.
Icant see any reason to bleed it twice.
Old Apr 16, 2011 | 11:00 PM
ricansdiesel's Avatar
hey crazy,where did you get the set up from? been thinking about doing mine for a long time now and i really like your set up...
Old Apr 17, 2011 | 08:58 AM
pipelayer4777's Avatar
Crazy how far back did you tie into the existing fuel lines? I was going to do the same thing when I changed my lift pump in the near future. I'm also gonna add a pressure gauge and pressure regulator with return so I can always see if I have fuel coming in to the IP. Mine are getting a little rusty, may just replace whole thing and can route any way I want to.
Old Apr 17, 2011 | 11:44 AM
Crazy's Avatar
I tie in right at back of the engine where the steel fuel ends and ran new line right to the IP and ran that line right lone side the intake
I got the set up at walmart where they sell the boating stuff
Old Apr 18, 2011 | 11:11 PM
zielinski.family's Avatar
What about your water in fuel light set up? Doesn't the fuel manager also have a fuel heater in it? Notice any difference in the performance of the engine since installing?
Old Apr 19, 2011 | 08:47 AM
Crazy's Avatar
No the new system dose not have the WIF or Heater. The filter i put has drain valve on the bottom of the filter and for as the heater most of fuel manager system i work on most heater where shot anyways
As for performance i have notice little difference there is lot better fuel flow i also notice fuel pressure stay at 7psi even under a load but i am running Heath Lift Pump.
Now if you want run a heater you can get the setup with heater and WIF in it but lot more money or can do what Ford did with there 6.9 and 7.3 get in line fuel heater which i may do if i decide stay in weather as for WIF i don't need it i drain my filter once month
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
