fuel system
Old Apr 1, 2011 | 09:43 AM
young gun's Avatar
Default fuel system
okay so i just bought a new truck. the guy kinda did it backwards in the build butwhats done to it is in my signature. so my question is:
what DV's do i have and should i upgrade them? and if so to what?
Also what lift pump should i use?and what GPH?
and how hard is it to replace a seal on the turbo shaft, exhaust side??
and what fuel plate should i use with this setuP? or should i just leave it out?
thanks in advaced!
Old Apr 2, 2011 | 10:51 AM
L6powered's Avatar
Toss the 370 marine injectors and get a better set with the correct spray angle.
Old Apr 2, 2011 | 02:30 PM
BIG NIG's Avatar
the 370's are old school cheap hp that smoke/haze
does it run out of fuel on the top end? no need to spend the money on a lift pump
i made 684.47hp on a stock fuel system
as far as what DV's you have, you need to pull one out and look at the number on the top and go from there
the turbo seal is easy just get a reseal kit and have fun
Old Apr 2, 2011 | 03:35 PM
young gun's Avatar
im gettin the turbo done by as new shop and they are cuttin me a deal. and it seems like i run out of fuel on the top end. butthe truck hradly smokes at all unless it gets boggd down. and what about a fuel plate profile? which one would it be best for set up? and should i see about advancing the timing? or wait til i get the trans done??
Old Apr 2, 2011 | 04:07 PM
BIG NIG's Avatar
with no plate and 370's it should smoke.....alot
with no plate it should smoke a little
timing will help with the smoke to a point
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
