Airdog
Old Mar 21, 2011 | 11:19 AM
vectorboy_99's Avatar
Default Airdog
I installed my airdog 150 last week. Everything went smoothly. However I noticed there is a wire by the pump marked, fuel pressure sensor, what does this plug into? And where would the sensor go?
I need to know.
Thanks for all the help.
Jim
Old Mar 21, 2011 | 12:45 PM
Default Re: Airdog
That is only if you to install there low pressure warning light.
Sent from my DROID2
Old Mar 21, 2011 | 02:15 PM
OK. I thought the system was already set up for a warning light. It says in the instructions to tape off the two leads for the warning light, if that is true why would I have to tape them off if the other end is hooked to nothing? The plug in I am referring too, is down by the pump, it's a green plug that is marked pressure sensor. I am confused why they want the two spade ends taped off up in the engine bay if the sensor end is hooked to nothing.
Jim
Old Mar 21, 2011 | 02:21 PM
KillStroker's Avatar
look at it this way think about the day you do get a sensor and there touch when you plug the connector to it? I dont know just thinking I would just cut them from the bundle for cleaner install.
Old Mar 21, 2011 | 05:32 PM
well it didnt really create a problem with the install. I was just wondering why it's labeled pressure sensor. But it 's ok. I am putting the sensor up by the pump with the adaptor from air dog.
Old Mar 22, 2011 | 11:04 AM
Pele's Avatar
The sensor that lives by the pump should be okay. It's a weatherproof connector and won't touch anything metal. The only way to get it to short out would be to stick a screwdriver or pin into it.
I just taped up the end of mine and zip tied it so that it won't get caught on road debris.
The two exposed connectors on the blue wires up front, however might short out against something. I taped those off as well and zip tied them under the Power Distribution Center.
I don't like to cut off wires because I might use them in the future. I still might put in a Low Pressure light even though I have a gauge. Can't see the gauge from under the hood and I might bump the wrong wire loose under the hood while I'm working on the truck... It'd be nice to have a warning that I can see from outside the truck.
acj
9
Dec 26, 2015 09:54 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
dirtymaxrens
Price Quote - Request A Price
Jan 24, 2015 08:02 PM
justinsbeck
Nov 21, 2014 11:53 AM
