47re to nv4500 swap
Old Mar 14, 2011 | 12:14 PM
Mattscat's Avatar
Default 47re to nv4500 swap
I am looking to swap my 47re to a nv45oo. the doner truck is a 98 12v and the other truck is a 2001 24v. Does any know if there is any thing i need to do with the computer in the 24v to make this work?
Old Apr 12, 2011 | 08:12 PM
nor cal cumins's Avatar
was asking the same thing.. it looks like the trans comp may have te be replaced cuz the 2001 comps are not refashable. idk man i might have to give in and just build up my 47re.
Old Apr 12, 2011 | 09:32 PM
turbostang7's Avatar
i went from a 5 speed to an auto and had to swap the tcm and ecm. but i'm pretty sure you can go from auto to manual without much trouble but not too sure?
Old Apr 12, 2011 | 10:10 PM
from what i have read the trans comp still thinks it has an auto in it and acts up..
Old Apr 13, 2011 | 08:20 AM
Default Re: 47re to nv4500 swap
True, but I would think all it does is stop you from going into overdrive or lockup which doesn't matter anymore but im not sure, I would say try it and see, will have to bypass the neutral safety switch. If it doesn't work keep your eyes peeled for a pcm ecm and trans harness from a manual truck they are all cake to change the harness is two simple plugs on the firewall above the valve cover is all
Sent from my DROIDX using Tapatalk
Old Apr 13, 2011 | 08:24 AM
Now that I think about it the pcm does have to be changed, iirc it will work with an auto ecm manual ecm combo but not the other way. Plus some people have problems with the dash not reading corectly and need a manual specific cluster, mine didn't read with the auto stuff in it. If you need one I have a manual cluster that I fixed and is working just needs the plastic cover over it from yours, from a 2000 manual truck
Old Apr 13, 2011 | 01:39 PM
weel see how it goes im prolly gunna end up doing the nv4500 swap..
Jonrarick
Oct 25, 2016 01:32 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
DuramaxBen
Feb 6, 2015 10:32 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
